Siemens обновил линейку 8 серии LOGO! до fs04.
Что нового теперь
1. расширилcя диапазон температур от -20 до 55 ° C, без конденсации
2. встроили Modbus TCP / IP-связи
3. дата-синхронизация с помощью NTP
4. доступ для записи значений процесса непосредственно в листе Excel в режиме RUN в LOGO! (фича на оф.сайте).
Все плюшки можно посмотреть в проге ЛОГО СОФТ КОМФОРТ, обновив её до версии 8,1. (и да руссификатор покамест не доступен, мотивация к обучению португальского,китайского и на худой конец английского).
LOGO! 8 is now offering a new innovation stage FS:04. The innovated LOGO! 8 products are available for immediate delivery.
LOGO! 8 Innovations:
Extended temperature range -20 to 55°C without condensation
For operation of LOGO! 8 at temperatures of -20 to 55°C for LOGO! 8
FS:04 basic units and expansion modules FS:03 (DMx and AMx).
Modbus TCP/IP communication in all LOGO! 8 FS:04 basic units
For communication with devices that support Modbus TCP/IP, e.g. Sentron PAC3200 for energy measurement.
Date and time synchronization over NTP in all LOGO! 8 FS:04 basic units
For automatic synchronization of date and time between LOGO! 8 basic units and other devices that support synchronization over NTP.
LOGO! Access Tool
For reading, evaluating and saving data with Microsoft Excel in RUN for all LOGO! 8 basic units.
LOGO! Soft Comfort V8.1 software
LOGO! Soft Comfort V8.1 offers the following innovations
Support of Modbus TCP/IP connections in diagram and network mode
Easy configuration for synchronization of date and time by means of NTP
New function blocks for conversion of floating-point values into integer values and vice versa
Automatic highlighting in color of special bit memories and reference lines
Additional reset function for shift register
Automatic installation of all standard languages (EN, GE, FR, IT, SP and CN)
Support of current operations systems (Windows 32&64-bit, Mac and Linux for 32&64-bit)
Additional sorting functions (Goto block number, etc.)
Larger area for bar charts in the message text
LOGO! Soft Comfort V8.1 supports all LOGO! versions
Compatibility notes:
Software:
LOGO! Soft Comfort V8.1 is required for programming the innovated LOGO! 8 basic units (FS:04). Upgrading is free of charge for customers with LOGO! Soft Comfort license. Upgrading can be done in the software (Help/Update Center). Alternatively, the upgrade can also be downloaded at http://WWW.siemens.com/logo and installed.
Hardware:
LOGO! 8 expansion modules with FS:03 or FS:02 can be used in all LOGO! 8 basic units.
Notes on the LOGO! starter kits:
The LOGO! starter kits are automatically equipped with the innovated LOGO! 8 FS:04 devices and LOGO! Soft Comfort V8.1 as soon as the current LOGO! 8 products are sold.
Innovated LOGO! 8 products and identifier:
LOGO! Basic units / LOGO! Base
modules
Name Article number/Order number Identifier Firmware version
LOGO! 12/24RCE 6ED1052-1MD00-0BA8 FS:04 V1.81.01
LOGO! 12/24RCEo 6ED1052-2MD00-0BA8 FS:04 V1.81.01
LOGO! 230RCE 6ED1052-1FB00-0BA8 FS:04 V1.81.01
LOGO! 230RCEo 6ED1052-2FB00-0BA8 FS:04 V1.81.01
LOGO! 24RCE 6ED1052-1HB00-0BA8 FS:04 V1.81.01
LOGO! 24RCEo 6ED1052-2HB00-0BA8 FS:04 V1.81.01
LOGO! 24CE 6ED1052-1CC01-0BA8 FS:04 V1.81.01
LOGO! 24CEo 6ED1052-2CC01-0BA8 FS:04 V1.81.01
LOGO!8 FS04 Новая версия и особенности
Хотите получить конкретный ответ на ваш запрос? Укажите артикул.№ вашего SIEMENS LOGO!.
Re: LOGO!8 FS04 Новая версия и особенности
Это что? Я теперь вместе с кодом заказа должен указывать FS:04, чтобы мне со складских запасов не продали какое-нибудь старье? Мда... У S7-1200 обнаружена такая же "инновация"...
Да, ибо если не указать этого факта, то могут fs:03 пригнать.
Потому как заказной номер (артикул) не изменился. А манагеры и не в курсе,что у них на складах то лежит.
Индитификаторный код указывается только на коробке.
п.с. несмотря что у меня уже пару проектов отрисованы в комфорте 8,1 под FS:04, мне не критично когда они приедут.
Просто я не помню анонса СИМЕНС РУС о том,что они доступны в России. Покапаюсь в почте.
Так жди, приедут FS:03.Андре писал(а):мне не критично когда они приедут.
поставкой занимается заказчик
моё дело прога + запуск в эксплуатацию
п.с. через неделю(может и две) должна приехать новая партия, посмотрю, какая версия и отпишусь
приехала 04 версия
